vor 8 Stunden schrieb norby:
Eine neue 4.0 ist Online. Veröffentlichung 26.11. Hier ist noch nichts davon bekannt.
Firmware 4.0
Dankeschön für den Hinweis...🙂
Anbei mal ein paar Informationen zu den Änderungen:
Sony A7rV 4.0: Benefits and Improvements
Shooting and Playback Functions
  • Adapts the display layout of shooting information for both horizontal and vertical viewing
  • Adds Spot: XL under Spot in the Focus Area menu
  • Adds Custom 1, Custom 2, and Custom 3 under Custom in the Focus Area menu
  • Adds Tracking: Spot XL, Tracking: Custom 1, Tracking: Custom 2, and Tracking: Custom 3 under Tracking in the Focus Area menu
  • Adds the Golden Ratio Grid option to the Grid Line Type setting menu
  • Adds the option to enlarge the menu screen display
  • Allows you to add OK/NG/KEEP flags to clips during or after movie recording
  • Allows the remaining capacity of both storage devices to be displayed during movie recording when using Simult. or Auto Switch Media (Relay Recording)
  • Adds support for the Relay Playback function
  • Adds a function that allows you to narrow down played-back images using multiple filters (e.g. Rating)
  • Allows Custom Key settings to be assigned to the AF-ON, AEL, and Delete buttons during playback
  • Adds support for importing/switching multiple IPTC Presets
  • Supports the Write Digital Signature function for still images and movies as part of Sony’s Camera Authenticity Solution
    • The timing for the provision of licenses (paid) to customers other than certain media outlets is yet to be determined.
    • Services may not be available in some countries or regions. For more information, please visit the Authenticity Catalog Page.
  • Supports Scan and Tag, Photo Cropping, and Volume Photography Commands under the Volume Photography License
    • Installation of a paid license is required for use.
FTP Transfer and Network Functions
  • Allows scheduling of FTP transfers while writing data to the camera’s storage media
  • Allows you to automatically schedule FTP transfers of protected movies and still images
  • Allows you to automatically protect movies/still images transferred via FTP transfer
  • Allows you to transfer specific images with priority during FTP transfer
  • Supports the following Monitor & Control app function:
    • Focus map display
      Note: The latest version of the Monitor & Control app is necessary. The app may not be available in some countries or regions.
Others
  • No longer supports the Security (IPsec) functionality
    Note: Please enable and use Access Authen. as it provides more secure protection.
  • No longer supports the WPA and WEP functionalities
    Note: You will no longer be able to select WPA or WEP when connecting to Wi-Fi. Please use the more secure WPA2 or WPA3 moving forward.
  • Fixes an issue where the focus may not reach infinity during Focus Bracketing
  • Fixes an issue where color reproduction may vary even when the white balance is fixed during exposure bracket shooting in lossless compressed RAW
  • Improves the operational stability of the camera
bearbeitet von blnmen
Am 29.11.2025 um 07:19 schrieb norby:
Das Drehen des Displays im Hochformat und das neue Touch-Menü sind eine weitere Bereicherung für die RV. Nur schade das nicht die automatische Motiverkennung mit implantiert wurde.
Das empfinde ich genauso. Die A7C II hatte die automatische Motiverkennung ja schon vor Monaten per FW erhalten. Dafür hat Sony die Drehung ins Hochformat noch nicht für die A7C II zur Verfügung gestellt. Hier bin ich aber zuversichtlich, dass das noch kommt. Bei der automatischen Motiverkennung für die A7R V sehe ich jedoch schwarz.
Moin,
vor 21 Stunden schrieb Shadow3561:
Moin,
Hat schon jemand das Update auf eine Grauimport Cam gespielt? Bleibt die deutsche Sprache erhalten?
Mit freundlichen Grüßen
Ich habe jetzt das Update von V3.00 auf 4.00 mit der Creators-App durchgeführt. Die deutsche Sprache bei getreckten Grauimporten bleibt erhalten.
Grüß euch,
habe gestern das Update gemacht und bekomme nun permanent eine orange Fehlermeldung am Monitor (siehe Anhang), wenn ich das WIFI aktiviere. Kann nirgends eine Beschreibung dieser Meldung finden. Vielleicht ist es ja auch nur ein zeitlicher Zufall.
Kennt jemand diese Meldung?
LG ToniK
